Prob about 40 years old, and the block of 7 slices has probably started to leak(or it could be the main lift ram seals)
Regardless I was in the notion of leaving the 2 outrigger legs on the stripped down block of slices, while putting the other 5 functions on 2 new joystick control valves.
Only I can't, since there will be 1 too many.
So, do I use a button on the joystick with a 6 port solinoid valve to split between the rotator and grab
, and what is the best way to pair the services.
Main boom and dipper arm on one?.
With the slew and rotater on the other, plus the grab on a button?
Or how?
Marcus
