Hi all a few years ago I bought a 2001 ec150/25 with fire damage (lister petter lpa3), I was able to rewire to get the engine running and chipping without no stress.
I want to get the no stress working but I need an image or wiring diagram of the controle pannel or a wiring diagram of everything for this machine as there are a few wires that I have bodged with inline fuses just to get running.
Also if anyone has any idea where or if I can still get pannels, I need a new/second hand controle pannel, hud, side pannels and fuel tank/ battery cover as I have made my own but I don't look very professional at the moment.
Thanks.
Edited by DTG-TREECARE
More info
Hello ,
I'm on holiday at the moment but I can email a wiring diagram over to you when I'm back next Tuesday if you would care to send me your email address  ?
I think GreenMech still have the console panel in stock but not so sure about the availability of the side panels or bonnet but I will check and let you know.
Jase.
Ok , we have the ignition console in stock and also a battery cover.
Engine side panels are unfortunately no longer available but we may have a later bonnet that could potentially fit ??
Jase.
Absolutely brilliant. Thank you. I will have the lot.
Bonnet frame out side edges is 660mm wide and 760mm long..
Also I am having issues with the button at the back of the chipper. I have a green light but rolers are only going slow. I have power in to the relay but nothing is happening. I think the rest is wired up correctly but unsure of this part
Firstly yes we have that panel....
The switch you show is a PB3 (press/pause/press) reset switch.
Press/pause/press because that's what you need to do for it to operate correctly..
Will still be available but might not be currently in stock , I'll check tomorrow..
From memory you can bypass it for testing purposes , I can talk you through it if you give me a call tomorrow on : 01789 400044 and the option for service..
Jase.
