has anyone got a 21 spline rear pto shaft to fit a 424.121 u1000 mog also looking for the standard size 1" 3/8 front pto shaft to fit into the pto reverser gearbox.
cheers
is the 21 splines on the very back of the shaft or in about the gaerbox, just if its to fit a imploments drive shaft then maybe it would be easyer to change the yoke on the impliments shaft rather than the mogs
im sure one of the mog breakers (price or atkinson) will have a front shaft as theres not many folk use them
:001_smile:
the 21 spline shaft is the one sticking out the back which you couple the implement shaft to. i did think of changing the yoke to a 540 6 spline but the mog shaft is a bit knackered from use by a previous owner!
front shaft is the 1"3/4 currently and wont fit the front pto reverser gearbox which is 1"3/8.
worth a try!!!
Yup that's the same as the one I currently have, rebuilt the bearing block with new seals etc but I need the smaller centre shaft that goes from the splined flange through the block. Cheers for you help David, will try the usual suspects for mog spares and see how much they want
