If you're just starting out and you need business, equipment, tech or training support you're in the right place. If you've done it, made it, got a van load of oily t-shirts and have decided to give something back by sharing your knowledge or wisdom, then you're welcome too.
Question
Ajdc
Last year I purchased 8 pleached copper beech trees, stems 1.8m tall, shoots and leaves already pruned onto bamboo frames. Received some good advice on this forum about roots close to the house, drainage etc.
Trees arrived as rootballs in Nov 2020 and planted. This spring leaves come out - so survived transplanting - but:
1. One tree is green-leaved, others copper. Clearly that is an error and I have raised this with company.
2. Of the remaining 7, two trees have large, deep copper leaves and come out earlier. Five have small, significantly lighter leaves that come out later. See photo. The trees were advertised as Fagus Sylvatica Alropurpurea.
So my question is this: in addition to the green-leaved interloper, have I also been sent two mismatched varieties of copper beech trees?
Many thanks.
1 answer to this question
Register a new accountSign in
