Hi
Small 7 tonne electric hydraulic splitter has just started shuddering and losing power.  Oil looked a bit bubbly so changed it.
But not sure how to bleed the system?  Any ideas??
There is an oil fill hole, a wing-nut "air valve" and a flat head screw that might be used for adjustment..
The oil should not be getting "bubbly" if there is a lot of entrapped air in the oil it will cause cavitation in the pump and damage it rapidly.
You need to find where/how the air is getting mixed into the oil.
It should not require bleeding, any air should get pushed out.
