15 hours ago, Paul in the woods said:
So, what do you do if you find something such as a firearm or ammunition?
More sensible to my previous answer.
If you have any knowledge of firearms, you'll be able to recognise an airgun. Many have been discarded in waterways over the years by disgruntled parents. Always check that it isn't loaded or cocked prior to any further handling. If knackered, put a grinder through the middle of the action and dispose of responsibly, be aware that there can be a powerful spring in there under compression even if it isn't cocked. Even though it is "only" an airgun, some can require a firearms certificate. Possession of such an airgun without a  fac is a firearms offence and the tariff is extremely punitive.
If in any doubt, they can be handed into the police.
If it's anything else or you are in doubt call the police.
If it's ammunition or ordnance, call the police. If it appears to be an explosive device, call the police using 999 and do not handle any further. Keep yourself and others well away.
If it's anything you are unsure about, call the police and they will advise.
Remember, it is now your responsibility.
Should add, although less likely, if it is a precharged airgun, i.e. has a cylinder with compressed air in it, these are extremely high pressure, some over 200 bar. Do not put a grinder anywhere near one of these.
