I have a 2010 Rodeo with a very small fuel leak, it’s coming from this breather pipe (see photos). When I open the fuel cap after a journey there is a build up pressure releasing from the cap. Just wondering if anyone has had the same problem before I go tampering with it
Thanks Jack
If you follow that breather back iirc there's a separator/valve designed to stop diesel pouring out in a rollover. I'd check that if it was me
Cheers paddy I’ll have a look
