41 minutes ago, Tippin Alaybye said:
I thought you did the idle first before high and low?
Yep.
Low speed fuel circuit will affect fuel mixture at high engine speed, to a small degree.
High speed fuel circuit shouId not affect idle speed mixture.
Both low and high speed circuits are in play at part throttle so both affect engine pick up.
I tend to go around the loop (low speed jet, idle speed, high speed jet) a couple of times if I have to do much adjustment on the first go round, just to be sure.
