Stihl 048 stops while idling
martin p
Or as it 'peters out' at idle  then a fuel issue.
Most likely fuel residue left behind as last fuel droplets evaporated out of the recesses and crevaces of the carb. Alternatively, it could be the rubber parts inside the carb have just got to the point they need a refresh.
Worth winding the low speed screw all the way in (gently) and back out to the same point as a quick and dirty test to see if it improves plus you get to know how far off std settings you are.
If it runs ok at speed give it a tentative run, might clear cobwebs out. But be wary of fuelling issues at high speed for fear of seizing it if fueling is wrong.
How fresh was the fuel before it went in the can?
Thanks , Managed to get a spare half hour tonight and put the carb adjustment screws back to initial settings ie 1 turn anticlockwise and tweaked the L screw to a nice idle and smooth pickup.
will  reset the H screw with a tacho tomorrow.
 Nice one, glad you got a result.
