MS881 vs MS660 Rim Sprocket compatible?
Bob_z_l
As above, thinking about a 881 and whether this will mean I need to spend more....
Are the 3/8 and 3/8 low pro sprockets a straight swap onto the New 881 rim drive?
Or will I need to buying new?
Bob
If I remember correctly, it’s the same as the 880.
[emoji106]
Bob
Yiu do know the 881 has a 3002 mount,
Not a 3003 mount like a 660/661?
[emoji106]
Sorry, No I didn't realise the mounts were that different. I was hoping to bolt my Panther and  42" GB  straight on. Dag Nabbit.
1 hour ago, Rough Hewn said:
Not sure what you mean...an 881 would be a major upgrade for me.
I don't want to side line the 660 but want to reuse/ share bars/chains and mill between the two head units.
I've stretched my savings and am read to commit to a 881.
Please forgive the simple way I look at things as this is a hobby/part time thing for me. Spending $$ on an 881 is significant outlay and I was trying to make use if what I had kicking around bar/chain wise.
Edited by Bob_z_l
Next mill size up!
A 42” bar gives 30”-36” max cut.
Great for small to medium logs with the 660/1.
If you’re getting an 881, you could get a 60-72”
Bar on a 60” panther mill with 48/50” cutting ability?
Cut very large slabs?
[emoji848]🤣[emoji106]
20 minutes ago, Rough Hewn said:
Next mill size up!
I get you.
I need 3 kidneys...sold one to afford the 881.  I'll need another for the super big panther.
Food for thought. Thanks for your insight. As always, greatly appreciated.
Bob
