Kubota B3030
Rolf
Morning all
Can anyone help out with this ?
my Kubota B3030s compact tractor 3 point linkage position control has begun to make a hissing noise ( pressure relief )
when the leaver is in the up position. Also it’s sensitivity seems to be compromised.
I recently serviced all filters and changed the oil but sadly it’s no better.
its the hydrostatic transmission if that helps.
Thanks in advance.
  • 4 weeks later...
On 04/08/2020 at 06:26, Rolf said:
Morning all
Thanks in advance.
I had similar on an old b1700 I discovered if the lift lever was all the way up, it tried to keep pumping oil, I just had to put the lever down a touch, that stopped the problem
32 minutes ago, Rolf said:
When you did that adjustment did your position control work as it should?
Mine is not, all sensitivity has gone and it work like a switch. Up or down.
Yes it did. Are you saying yours is either fully up, or fully down, and you cannot choose any point in between?
