I have a 2009 Rayco 1625-A Super Jr stump grinder. The rear tire on the operator side of the machine looses air around the valve stem.  Looking for info on how to remove the tire so I can get it repaired.  Any info will be greatly appreciated.  Thanks in advance.
Pop off the round cap in the centre off the wheel with a screwdriver, you’ll see a big nut with a split pin, pull the pin out, and loosen the nut, then use the cutting head to raise the wheel off the ground.
Remove nut and wheel will come off.
Edited by Mick Dempsey
