Nearly finished this, push-pin lock, ash lath, 45lb draw (I know that's tiny - like a kids longbow but still a lot of fun), stock and tickler are mulberry.  The tickler is steam bent. Bolt clip is water buffalo horn, dry-heat shaped, inlays are antler (string slot) and bone (bolt rest).  I made so many mistakes I nearly gave up, biggest problem was a huge tear-out around a knot just behind the string-slot which resulted in a very slender tiller, which in turn meant I had to go to stirrup rather than wippe.  I want to re-do the bindings and still have to twist up a decent string and fletch a set of bolts but the wood-work is all done.
Edited by stuckinthemud
  • Like 8
