If you're using it for private use then you take your chances. If your using it at work then it looks decidedly dodgy to me- no guarding, no emergency stop?I certainly would let anyone working for me use it
Another thing to consider is that you need to use a vehicle with a diff lock. If you dont, you'll need to lock the wheel on the opposite side of the axle. This will mean that the diff is spinning continuously whilst the splitter is in use which they are not designed to do. Diffs normally move very little when driving and occaisionally if you wheel spin but I wouldnt want to be spinning one continuously.
