Hello,
What bar fits a Tajfun 400 processor?  17" 3/8 husky?
thanks
Any 18". 058 bar with a little adjustment of the stopper on the bar ram.
Best off going for a cannon if you want longevity! Semi chisel chains also last considerably longer and grade your timber and only put full chisel on for stuff over 12" even then the benefit of cut speed probably isn't beaten by the need to change chain slightly more often. If its clean timber though its worth it.
