New log saw
Toylexus
If you dont mind paying, the Binderberger, supberbly engineered, galvanised and painted, unless sommat has changed from 10 or 15 years ago. I proper lusted for a Binderbeger or Posch.
BUT
I bought a significently cheaper PTO Krpan, from Marshalls(also Binderberger agents, or at least they were) which satisfies  my limited needs.
My opinion only, but consider a log elevator, as the difference in being able to let the cut logs drop into the hopper and be "whisked" away, to a trailer, bulk bag, or even log pile,  it simply makes such a difference to productivity.
Because I also bought a Krpan telescopic log elevator, and back then, from recall, it was about £2000.00 well spent.
Cheers,
Marcus
p.s.
I tried the 230V Krpan, but it was distinctly under-powered, even with a brand new sharp blade and not having 3Ph I had to go PTO, but otherwise 3Ph every time.
