Morning,
A bit of a longshot perhaps but has anybody got the dimensions of the a530 rollers? The parallel bottom roller diameter, and the diameter of the smaller and larger end of the tapered top roller?  I've had ours built up and reground them a fair few times and would like to try and get them machined back to original dimensions.
The price I was quoted for a new set was a tad eyewatering!
Cheers for any assistance.
Description A 530 (XL) A 540 A 425 A 328 A 231 A 141 XL
Weight of the flywheel 70 kg 120 kg 150 kg 170 kg 275 kg 385 kg
Dimensions of the flywheel 600x25 mm 650x30 mm 730x30 mm 820x35 mm 970x35 mm 1060x40 mm
Diameter upper roller 110 mm 135 mm 120 mm 160 mm
(option 200 mm)
160 mm
(option 240 mm)
200 mm
(option 280 mm)
Diameter lower roller conic 110 mm (middle) 120 mm 120 mm 120 mm 160 mm 160 mm
