  On 02/09/2019 at 15:03, Arctostaphylos uva-ursi said:
If its sandy soil with few stones 1 to 2 hours 1 - 2 hours If there are large stones/boulders then it will take much longer.  If the root system is very dense it will also take much longer.  Very difficult to answer such a question as there are so many variables. Only way to get a good idea is to dig a test pit.
Expand
Is that with a soil extractor? I just checked the soil volume from the pic that I posted above. It is 20m3... So we are looking at 20 to 40 hours per tree, assuming not extra difficulties...That is a lot.
Anyone have experience with clayey soil?
Cheers,
Island
The lighter the soil the quicker it will be, airspading takes a very long time! If you are looking to remove around 40m3 of soil you would be better off trying to source a hgv mounted soil vac. In my experience it would be 1-2 days to complete your excavations.
Expand
Thanks for the reply. 1-2 days with the hgv mounted vac or just with the airspade? I am, so far, thinking of using an airspade 2000, 105 cfm or 150 cfm 4ft barrel, with this:
GUARDAIR.COM
Powered by compressed air, Guardair 55 Gallon Static Conductive Drum Vacuums are ideal for vacuuming up chips...
It all depends on what I can source and the price. India has limited choice for this sort of stuff.
So I have inquired about the soil texture:
Texture of most soil to be excavated:
Clay: 20-25%
Silt: 30%
Sand: 35-40%
Gravel: 5-10%
Does that help someone to give me an idea of time/m3?
Can the vacuums move the soil from one point to another instead of just into the barrel? I need to place it nearby and then move it back once I am done with the tree.
Thanks
Edited by Island Lescure
mixing up structure and texture...
Read more
