22 hours ago, richy_B said:
 I looked at mini artics (Iveco 50c SWB with a gooseneck trailer for example which could tow a plant trailer with a payload of about 5,500kg).
My 50c has a GTW of just under 9000kg (8750kg ish I think).
Unladen weighs about 2500kg
Trailer of that type to take heavy load must be 1500-2000kg
Might struggle to get 5500kg payload.
You need one with a bigger GTW than a 50c unless some have more than mine does.
The 65c, 70c and 72c have a 11,500 GTW I believe.
I was going to suggest checking out what the bigger ones can do. I just happen to have a 50c that you mentioned that I use as a C1 training vehicle for the 7500kg licence.
DRIVERTRAINING.CYMRU
Learn to drive a C1 7500kg 7.5 tonne vehicle or add C1E. Courses run in North Wales
Just doing a C1E and O license and all the associated gubbins at the moment.
It is primarily to replace my transit t350 tipper with a 7t tipper. I have looked at a 70c tipper. I have a 90hp tractor but I don't want to go down the tractor towing route, I want to keep it all clean cut and legal.
Edited by richy_B
Have you already got the C1?
