Heizohack 12" chipper: changing blades
Sutton
10-15 minutes if you know what you're doing and replace them with equally new/worn ones so there's no need to line up with the bar. Probably double that if you have to fiddle setting blades.
It's two bolts on the cover then one to slacken on each of the six blades. An impact wrench will save a fair bit of time.
Read more
