The choke rod doesn't stop the saw but helps to start it. When you lift the choke lever to the stop position the black wire connected to the lever from the coil touches the spring and contacts the short yellow wire connected to the saw body by a bolt grounding the coil and cutting the spark. On a saw I repaired the wire came off the choke lever and I had to put a small tie wrap round it to hold it in place otherwise it had the same problem as yours. I stopped it by pulling the trigger to rev it then pressing the choke down and gassing it up but after the fix it worked as normal.
Edited by peatff
