When I started out nearly ten years ago I worked out of home, as the business grew I needed more space so rented a garage, then as I found myself with more and more equipment I rented a shipping container as well. The business is still growing, I need even more space but can’t justify the expense of a proper industrial unit. It’s already a bit silly having gear dotted around three locations but as long as I’m organised it’s manageable, but a fourth would be impractical. Has anyone faced similar problems? If so do you have any suggestions?!!
Thanks
Rent a portion of a farmer friends field/building? get more shipping containers and arrange them to suit your needs and even act as a security scenario when you lay them out. Stack em on top of each other if ya need. If a power supply is an issue then a generator housed in another shipping container could be an option.
