I have a Husqvarna 350 and lent it to a neighbour who found the chain had became stuck.
I opened up the case to examine the chain and whilst releasing the bar observed one
of the bar bolts disappear into the oil tank behind it.
Does anyone know how it can be retrieved and refixed please.
Its fiddly. Bit if thin wire with hook/long nosed pliers/ magnetic stick. Once you have enough poked through from oil tank, you can hold the threads and locate the square end in the tank. Pita
