Hi everyone I'm just in the throws of a rebuild on a entec ch25 everything seems pretty good apart from the stress management missing completely unfortunately the kholer engine that was on it has been swapped out for a copy which is fine runs great etc etc question is besides the flywheel (chipper side) sensor does the stress management need an engine speed sensor either from an ignition coil or alternator pick up to it make it work ? or does it solely rely on the fly (chipper side) wheel sensor and 12v from the battery to power it ? Any information would be great cheers in advance
