Has anybody brought the 150 blades from wood chipper blades on eBay?  I’m asking as they the lowest price and just wanted to know if they any good? Spectrum, northern arb and L&S engineers all supply the blades but if they are the same quality and £15 cheaper each - then I’d rather go with the lower price option.
Edited by Woodislife
Your question comes down to them being either genuine Timberwolf sourced or copy parts.
Block exemption regulations within the motortrade sector meant that you can fit non-genuine parts to vehicles as long as they had the correct accreditation this isn't always the case with machinery. For the cheaper non genuine parts you have to ask about the warranty cover , ourselves at Green Plant & Spectrum etc being dealerships will have the back up of Timberwolf and if there is a problem with the blades they take it very seriously .  Would a non genuine supplier be as thorough ? Gareth of Green Plant 01483 235111
Not worth the risk. Genuine TW150 blades are cheap anyways.
As said above if you have a failure and fitted genuine items to factory specification then the chipper manufacture will take it seriously.
