Hi all i am looking for a owners manual for a Jensen A528 chipper which i have got second hand which has had a engine rebuild but i think within the process the chippers wiring has been disconnected as i don't think the chipper side is working correctly as the feed rollers stop if you try to put anything in greater than one inch. forward and reverse works and speed works. any help or pointers would be great. thanks.
Sounds more like rollers not getting enough hydraulic pressure , maybe valve controlling forward/reverse not functioning properly .
