I'm looking for cord or arb waste to turn into logs for next winter ( home use ) Located between Northlew and Highampton in Devon . Can dispose of chip as part of deal if needed .
I do the same, process arb waste for home use (chain saw and axe).  I sent messages to a few local tree surgeons before finding one that had more wood than he wanted for his own use and if he is passing will drop it off rather than take it home.  You have to not be fussy as to what wood you get but it is great way to heat the house and get some exercise.
There is also the tip sites part of this web site but I've not ventured into that as I don't have good access and my contact can deliver more than I can burn on my 5kW wood burner anyway.
Thanks for the encouragement , Ive only just moved to the area so am trying to make some contact with local surgeons , Ive registered on the tip site as I have good access and plenty of room to compost up some chip .
