We had this on a TW230 last week but on a road tow.
Remove the belts again, does the engine start up? On the one we had in the flywheel was heavily blocked mulchy crap. The starter would turn the engine /flywheel over but not fast enough to actually start up.
We removed the panels to give access to the flywheel, really carefully removed all the built up debris in the chip chamber, turned the flywheel over with a bar, removed more debris until we could turn it over by hand. Re fitted the belts and it fired straight up. We then noticed no air flow coming out of the discharge chute so stopped the machine, removed the chute which was blocked up solid, un blocked it and then all was good.
