In theory yes you could !
But seriously it’s not designed to do that and it would void any warranty you have!
Your hydraulic system in your chipper is closed circuit if you start splitting joins apart or fitting QR fittings then you run the risk of getting contamination in the hydraulics and then your be buying a new pump, oil and filter!
Which would be the biggest part of buying a chipper with its own engine and pump and if you sell your current splitter your be even nearer!
Great thanks [emoji16][emoji16][emoji16] it was just a idea id been roling around tbh[emoji848] but was not sure if a good one as don't know about pump pressures ECT and your completely right about oil contaminating/warranty mate did not think about that[emoji850][emoji23] I'll just go with plan A (little wood possessor)[emoji6][emoji6][emoji6]
  • Β
Arbtalk.co.uk is a hub for the arboriculture industry in the UK. Β
If you're just starting out and you need business, equipment, tech or training support you're in the right place. Β If you've done it, made it, got a van load of oily t-shirts and have decided to give something back by sharing your knowledge or wisdom,Β Β then you're welcome too.
Γ—
Γ—
