Installing cobra
atree
hi guys
Ive got to install two cobra cable braces on monday in a pin oak(I wont see the tree till monday)One is at 6meters and one at 8 meters
Its been ages since i last done one,and ive forgotten how to install them??
Advice and tip would be great
cheers
bits-
rope stuff
plastic spacer things
protective sheath (to be cut to size)
dildo
lube if its the older stuff
circular date tag-possibly
shrink wrap
shrink wrap an end of the rope stuff (i cut rope to length in the tree) insert plastic things into rope by opening rope by pushing together, slide over protective sheath which youve cut to size to suit the limb/trunk, wrap round trunk/limb with spacer against limb/trunk, tail needs to be long enough to be inserted about a foot, taken out, a small loop made and inserted again for a bit, and pull end out a few inches
insert dildo in middle, use lube if tight
offer up other end of rope to and around limb, slide over date tag if applicable, insert plastic thing, then cut to size, repeat as above
i find electric tape better than shrink wrap, and inserting as much as possible of spacers/dildos before i go up-easy enough to slide them along if not in right place
