9 minutes ago, AA Teccie (Paul) said:
Hi Kevin, see below (I hope)...obviously now superseded by the planning portal.
Regards,
Paul
tposguide.pdf
You are a LEGEND Paul!!!  ??????
(I hadn't kept a copy because it was obsolete, but was frustrated by not being able to cross read a foot note from Mynors which referenced it). ??
Edited by kevinjohnsonmbe
10 minutes ago, AA Teccie (Paul) said:
"Glad to be of service"...if only occasionally :/
Tbh it's occasionally referenced on UKTC for topic areas where the planning portal isn't particularly helpful or advice seems derived from it.
Cheers Kevin, hope you're well.
Paul
Much obliged Paul!
Great Cornwall Branch seminar recently with Mr Barrell as headline speaker!  Work as busy as ever but broken toe last Thursday is causing some considerable pain and immobility ? (not to mention embarrassment since it happened whilst kicking a 15 year girl!)
Maybe at least I'll have a quieter run in to Christmas this year (but at the expense of having to catch up in the NY (face palm)).
New projects on the horizon for the new year which may well give me the kick up the backside to finally start the accreditation process...  A few loose ends to tie off first but looking likely!
Sympathies, having previously having had a broken toe, and bemusement, given the circumstances resulting in such ("yours" not mine...being football related) and hoping for your speedy recovery.
Glad the Branch event went well and Jeremy's always a good presenter, oft very direct and contentious, but otherwise just very well informed and experienced.
Look forward to hearing more on the accreditation process in the New Year...2019 hopefully ;)
Cheers Kevin, ATB..
Paul
Cheers Kevin, ATB..
Paul
She was an entirely consensual TaeKwonDo participant Paul....  (honest guv!)
(rather embarrassing that I 'broke' myself against her - in a manner of speaking!  ?)
