Loose clutch housing husky 555 brush cutter
Marsh Monkey
Hi guys my brush cutter has developed an annoying wobble to the engine I've tracked it down to being a loose clutch housing. But the bolts aren't loose I've tried the old favorite of taking off  cleaning and putting back on but still loose. It went in under warranty for the same issue but I'm unsure of how it was sorted out any ideas
If your stuck on something that has happened before ive  always found that if you ring the guy who fixed it they are only too willing to tell you what was wrong with it the first time. Chances are they will over egg the pudding so you take it back to them for repair but at least you can weigh up if you can tackle it yourself.
