Hi there my TW190 seems to be having problems with the none stress, it is working but i would say that its kicking in way to late is there a way of resetting like on the Jensens or is there something i could check ?? The belts are tight.
Thank you in advance.
Regards Dan
Hi Dan,
no its not possible to re-set. Belts would be the first check point, 5mm deflection or thumbnail width. Also have a look at the alternator belt. is it an EPS1000 no-stress unit ? coz they were never the best , but tended to just stop working completely rather than go slightly faulty. I can get a technician to talk to you if you need more help .
good luck -  Gareth of Green Plant.
Thank you for that Gareth yes that would be a good idea my number is 07999671445.. We have used the machine again this morning and the none stress is working but compared to how it was it is not kicking in right till the last minute..
Regards Dan
