Hydraulic tipper not working
Con
Its a process of elimination. Check continuity of wires: To tipper switch / From tipper switch to solenoid / from battery to solenoid / from solenoid to tipper motor.  If no continuity then either a break in wire / loose - corroded connection - corrosion inside a cable crimp end.   Test tipper switch works. Best way to test continuity is with a multimeter with an audible continuity test function.   Sounds like an issue with the tipper motor though and the live feed to solenoid also if no voltage there.
