Cs100 greenmech fuel tap
Newms10
You are missing the 'extension piece ' which is basically a twisted piece of heavy gauge wire , it pushes over the fuel tap which is buried under the fuel tank and comes out through the rubber grommet in your picture allowing easy operation of the tap.
The part will be readily available from any 'Briggs' dealer..
