The stream is being effected by Acid Mine Drainage (AMD). It happens when old sub-surface mines are abandoned, which then flood (since pumps no longer run) and begin to overflow into wetlands and streams. It's common for this run off to be acidic and contain toxic metals. To be honest I'm not a geology or biology or chemical expert but it's clear something is very wrong in this stream valley. The mine at this site has probably been closed for 60+ years.
Here's a information rabbit hole to venture down if you're interested https://en.wikipedia.org/wiki/Acid_mine_drainage
Read more
