Hi,
I need to get some parts for my EC150. The control arm for the feed is loose and the swivel where it goes into the valve block broke the other day, its temporarily fixed but needs a new arm section.
Any ideas on a drawing for parts or a good contact for getting parts?
much appreciate if you have some contacts etc
We may be able to sort something out and supply it through your local GreenMech dealer. Or, if I read you correct, the lever turns in the receiver on the spool valve. Originally, it was a bolt welded into the arm and held into the receiver with a grub screw.?
