hayter harrier varidrive belts replacement
pmb111
You can change both belts without any dismantling, apart from the underdeck cover, The smaller left hand side part of the underdeck.  Then you can roll the belt off as you did with the engine to variator one.
What size is it, 41, 48, or 56?
