Morning all.
Anyone in or around Golders Green on 20/03, and have 45 minutes they're looking to fill? Small Hawthorne stump in a back garden needs grinding out in order to accommodate a shed base being set there.
The grinder must be narrow enough to fit through a standard doorway as it's a through the house jobbie. Unless it's tiny enough to be moved down a 60cm alley?! Fortunately no need to worry about mess through the house as the building is derelict.
There's £80 on it.  I'll be on site to help with moving the grinder, and I'll do the clean-up afterwards so you can get on with your day. If you're interested let me know.
Will
