Loose logs, approx density
Woodwanter
11 hours ago, SbTVF said:
Weight density? At what moisture roughly? Fresh cut or dry?
Both really, some will be dry, others freshly cut.
10 hours ago, Big J said:
I did a 29 cube load of fresh oak at it weighed in at 11.4 tonnes, so 2.54 cube per tonne. Softwood a bit less generally, unless it's very wet chipwood (top sections of the tree are much sappier, and therefore wetter).
Thanks - sounds like my fag packet calculation wasn't too far off then!
A loose cubic metre bag of sub20% hardwood weighs between 275-350kg depending on species. Oak/beech being on the heavier end. On my experience at least.
Wet? Maybe 500kg or thereabouts per cubic metre. I know our mustang with a 900kg lift will manage 2 IBC’s but can be a bit wobbly if there’s a heavier species in there.
