Timberwolf sub forum
cordwood
Struggling to remove the flange on the bottom feed roller ,where the hydraulic pump connects to the roller. The pump shaft isn't worn just the female end on the roller. I've removed all of the bolts but can't seem to split it. Is the answer to weld a nut on and have a go with a slide hammer? Or is there an easier way?
