I note the radiator on the engine on my enter has no header tank for the water. I topped up to where I thought the level should be, and noted that after each use, a little of the water had seeped out the overflow pipe.
Now, after 25 hoursnuse since the full refurb, the level is just below the find inside.
Is this the correct level I should be maintaining?
