ms390
THOMAS85
When you fill the tank and screw the cap on, it is possible the pressure in the tank forces fuel past the needle valve in the carb and floods the engine. It is possible to see it if you fill the tank with the air filter off and screw the cap on whilst looking up the bore of the carb. If you can get a bit of an angle on the saw so any fuel runs out the back of the carb rather than in to the engine, it may prove the point.
The cause - weak metering spring, metering arm too high or the needle valve a bit worn.....that is if I am correct in this analysis!
When the saw is warm, it probably vaporises the extra fuel but floods the saw when cold.
