On 01/10/2017 at 19:35, spudulike said:
Can we confirm that it has a new OEM kit on it or some other Chinese poop and it is also worth making sure the piston was fitted the correct w
First one was chinese cheapo then other was bit better think it was farmertec or summit not sure if its chinese or not and yes piston was installed correctly
The most common issue will be with the carb but it is possible that compression is dropping off with heat after use so measure the compression when it has lost power and expect 140+ and if this is OK them most likely a carb issue but don't rule out coil, HT lead and plug as previously mentioned.
