ok, so i replaced the fuel breather with one from an old saw of mine, and but the old gal back together...
moment of truth, pull, pull, pull..... and no luck,
i tried a drop of fuel down the bore, pull,pull pull.. still nothing,
i am somewhat confused now, as i have cleaned the carb, checked all pipes for blockages, there is lots of compression and a nice spark, but the fuel is just not getting burnt (if getting in atall) the saw fired up fine when i baught it, but now i cannot get any life from it, i am going away for a week on saturday, so if i have no luck by then i will have to put it into a shop (which i loathe because its alot of money for someone to do what i can do...) but maybe they will have some luck, or they no something i dont....
what sort of compression are you getting? thats very odd if you have compression and and a spark but it wont fire, im at a bit of a loss without seeing the saw, sorry i cant be more help
If you've put petrol down the bore and no luck, I'd be thinking about ignition. You can sometimes get a good spark with the plug out, but no spark under compression.
Some mechanics have a test plug, with the gap about 4 times what it 's supposed to be. If the spark can jump that gap, it will jump the normal gap under pressure.
Hey quickthorn,
thanks for throwing that idea into the pot, i will try it out, but if it can't jump a large gap but can jump a small gap what could be the problem/remedy?
Thankyou
JR
