Some Professional Advice Please
Brian S
Question
As you know I'm not an Arborist, just a home firewood logger
I have 2 Chainsaws, a Dolmar 14" petrol and a Titan 14" Electric
Both have Oregon 3/8th chains, is there any other info I need to know?
Now I would like to "freshen" up the edge, and have come across the Stihl 2 in 1 sharpener. looks both quick, and efficient, and most importantly, fool proof :biggrin:
Can I use it on these chains, or are Stihl and Oregon chains set differently.
Or if they are set differently, and I use the sharpener, would it have a good or adverse effect on the saws
You need to determine the type of cutter and as a result the pitch and the gauge . The type of cutter will determine the file diameter that you need to sharpen it correctly . The pitch is the distance between any 3 consecutive rivets divided by two . The gauge is the thickness of the drive tangs that sit in the bar . If it is a 3/8th pitch chain it can be one of 2 different file sizes . Standard 3/8th is sharpened with a 7/32" ( 5.5mm ) file . 3/8th pitch LOW PRO is sharpened with a much smaller 5/32" ( 4.0mm ) dia file . You say its 3/8ths but just in case ......If its a .325" pitch chain then you need a 3/16th ( 4.8mm ) diameter file . Bit complex I know but you will get used to it .
Edited by Stubby
