I'm not to sure about this but very willing to learn more if you could tell me
Basically it's just a big gear. Say the drum has 20cm of cable thickness on the drum the outside is 20cm further away from the drive so the bend radius is bigger so the gearing is higher so you get a faster line speed. At the bottom of the drum you get more power but less line speed.
Ah ok, so as the wire pulls In u get less pull? Is that correct
