Husqvarna is listing a 10" and 12" carving bar that appears to be available in Europe and soon in the US.
It is a laminated bar and I assume has a welded hard nose tip.
Has anybody been using this bar had the tip fall off (as does the Stihl laminated bar)?
I believe it is intended for use with the Li series Husqvarna saws but will fit the 240e and 543XP (and a few others that are higher power than the AP chain is rated for.
ROOSTER
I should have included the part numbers
587394460
HUS 10" CARVING BAR 1/4, .050
501844060
HUS 10" CARVING CHN 1/4, .050
I have also seen somebody on ebay.uk selling an MS170 with teh Husqvarna bar mounted. Comparing image profiles it appears that the mount holes would not line up properly and the bar would have to be shortened?
Personally I would not buy a laminated bar.
I am just questioning whether anybody has used it and had any opinion.
Thanks
