husky 268
SEAN TYNAN
The oil pump can be adjusted
to give four different oil flow
rates. To adjust the flow rate,
first remove the chain, bar,
clutch cover, centrifugal clutch
and the clutch drum. Using a
screwdriver, adjust the oil flow
rate by turning the adjuster
screw one way or the other.
The projection on the screw
should point towards the
chosen setting.
(cut and pasted from the operators manual found here->http://weborder.husqvarna.com/order_static/doc/HOEN/HOEN2001/HOEN2001_1019196-26.pdf)
