stihl ms391 ignition
kier
I have a ms 391 and the spark has gone , I diagnose it as the coil having given up , seems I can only get an original part from Germany at £52 .
90 odd here ,
but there is a ms361 part that looks identical (£14) , my question is has anyone fitted the 361 part on a 391
otherwise its been reliable
Parts can look the same but operate very differently, found this out on a Kombi trimmer where the Chinese unit backfired violently. Most coils trigger pretty much when they go over the coil but some have a delay built in so they spark well away from the coil and TDC.
No idea if it will work - up to you if you want to spend £14 to find out!
the part arrived today and it fitted and the chainsaw now works , the spark looks a bit weak, does it make a difference what the gap is between the flywheel and the ignition unit its about 1mm at the moment
It should be set using a business card or a 5 thou gauge. 1mm is much too large and you risk having the spark fail or the ignition timing being retarded.
